Return actual Rotation from a layer Auto-Oriented along path
Mikael Holmström
on Jun 30, 2016 at 7:17:47 pm
Hi all,
I would like to inherit the actual Rotation value from a layer that is Auto-Oriented along a path onto the rotation property of another layer. I would like this to happen with a small delay. I have tried:
thisComp(layer(”Auto-Oriented_layer”).transform.rotation.valueAtTime(time-i))
but it doesn’t consider the rotation that is caused by the Auto-Orientation mode.
Mikael
Kalle Kannisto
Re: Return actual Rotation from a layer Auto-Oriented along path
on Jun 30, 2016 at 8:27:02 pm
This Dan Ebberts expression gives you the rotation value, just need to modify it with valueAtTime()
L = thisComp.layer("Auto-Oriented_layer");
v = L.toWorldVec([1,0]);
radiansToDegrees(Math.atan2(v[1],v[0]))
Mikael Holmström
on Jun 30, 2016 at 9:06:07 pm
Thank you. Do you have an idea where to put the ValueAtTime() to make it work?
Walter Soyka
on Jun 30, 2016 at 9:52:38 pm
toWorldVec takes time as an optional second parameter.
Walter Soyka
Mikael Holmström
on Jun 30, 2016 at 9:55:39 pm
It works like magic, thanks!
