How reset beginning of fotage layer.
Pedro Miralles Lorenzo
on Jun 29, 2016 at 10:04:32 am
Hi there..
I'm working in a tv show and i have a lot of shots that i have to key and put it a background.. but then i have to adjust it the in and out for each layer. The idea is select and duplicate all the original all layers and substitute all for the animated background.. but some times the duration of the footage is longer than BG..
Do you know a shortcut or script to slide layers in the time line to apply many layers in at same time. like went you use the Y key but because all videos have a different duration i must go thru layer per layer.
here is an image to what a mean.
10241_qq.jpg.zip
Thanks so Much
