Final post for a while - Last two effects i need.
Shaun Pokines
on Jun 27, 2016 at 1:56:08 pm
So, in this promo, it erodes away like being completely erased.
time-scale 0:11
Last two
Teen Wolf oozing out Black on the logo, like dripping.
time-scale 5:49
Teen Wolf breaking pieces off, rocky finish
time-scale 1:30
Kevin Camp
Re: Final post for a while - Last two effects i need.
on Jun 27, 2016 at 4:53:26 pm
the first one is pretty simple, use the gradient wipe effect (or cc image wipe).
but first you'll need a gradient to use as the gradient layer. find or make a cloudy grayscale image (photoshop render clouds, or pre-comp a layer that has fractal noise will work pretty well).
add that gradient layer to the comp with the logo (or layer the will 'erode' away), then add the gradient wipe effect to the logo. select the gradient layer as the 'gradient layer' in the effect and the animate the transition property. fiddle with the settings as needed.
you can get more complex, as the effect will also use footage (like time-lapse clouds) or an animated gradient layer, which can be pretty cool.
---- edit ----
you could also use the footage/render clouds/fractal noise layer as a track matte, if you prefer.
one way to do the dripping effect is covered in this tutorial:
https://library.creativecow.net/articles/rabinowitz_aharon/horror_text2/vid...
and the crumbling likely uses the shatter effect. that effect is pretty deep, but if you search for tutorials that cover creating custom shatter maps, and controlling shatter using gradients you should be able to learn what you need.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Shaun Pokines
on Jun 27, 2016 at 6:10:58 pm
What about the rocky style, the last one
Shaun Pokines
on Jun 27, 2016 at 6:11:53 pm
Nevermind
