Mask path showing up in final output
Kieron Hazel
on Jun 25, 2016 at 11:01:10 am
I hope someone can advise with the following problem I am having in After Effects CC. I have drawn a mask using the ellipse tool to block off the edge of an explosion. The mask is working as a mask should, but when I output the file the path of the mask appears in the final output so it looks as if I have an animated ellipse moving around in the video. I can see no obvious way to prevent this from happening. Many thanks for your help.
