Importing AE, PS, and AI files
Jerry Smith
on Jun 23, 2016 at 10:55:37 pm
OK, this will be the first of a few questions that you can file under: "everything you wanted to know but were afraid to ask about AE".
If I import an AI or a PS file into AE and then change the AI or PS file those changes show up in AE. Something like this definitely happens. I've seen it! :)
On the other hand, if I import AE project 1 into AE project 2, close AE, then open AE project 1 and make a change, and then close it and open AE project 2, nothing will have changed in AE project 2.
Have I got that right?
Thanks in advance
Greg Gesch
Re: Importing AE, PS, and AI files
on Jun 23, 2016 at 11:08:59 pm
Hi. Yes, you've got it right. Any changes made are only saved in the file they are made in.
Walter Soyka
on Jun 24, 2016 at 12:16:12 pm
[Jerry Smith] "If I import an AI or a PS file into AE and then change the AI or PS file those changes show up in AE. Something like this definitely happens. I've seen it! :)"
Importing footage creates a pointer in the After Effects project to the media. As you note, changes to the media will be reflected in Ae.
[Jerry Smith] "On the other hand, if I import AE project 1 into AE project 2, close AE, then open AE project 1 and make a change, and then close it and open AE project 2, nothing will have changed in AE project 2."
Importing a project is different; Ae does not point back to the original AEP. Rather, it copies the contents as they were at the time of import into the new AEP.
There's a product over at Aescripts that lets you sync projects, more like the way you describe:
http://aescripts.com/project-sync/
Walter Soyka
