achieving this text extrude animated effect
Wilson Costa Campos
on Jun 23, 2016 at 10:37:50 am
Hi everyone,
I was trying to achieve this sort of effect that can be seen at https://vimeo.com/146869349 at around 2:42s
Played a lot with after effects but couldn't get the right look..
Seems to be a directional blur but can't get quite the same effect. could it be that it has a mask? but that would require a lot of work..
if anyone knows or has an idea I would immensely appreciate it!
Kind Regards!
Wilson
Walter Soyka
Re: achieving this text extrude animated effect
on Jun 23, 2016 at 11:36:08 am
I'd guess this was originally done in a 3D app, but you could pull off something similar with a fake 2.5D extrusion in Ae -- set up many stacks of layers for each letter, offset by a single pixel or less in X, Y and Z.
Something like this script could be helpful:
http://aescripts.com/3d-extruder/
Walter Soyka
Joe Clay
on Jun 23, 2016 at 3:10:37 pm
Interesting, I wrote a plugin with similar functionality. It has some bugs I haven't been able to fix so I haven't released it yet. :/
Anyway, you might be able to get away with a few directional blurs, and some masks on the opposite side of the text. You'll probably have to precomp it to do that.
Joe Clay
Workbench.tv
Kalle Kannisto
on Jun 23, 2016 at 3:14:22 pm
Here's a fun one for you. Duplicate the layer a bunch of times (about 8) and see what happens...
10219_blurtrail.aep.zip
Wilson Costa Campos
on Jun 23, 2016 at 4:29:19 pm
thanks a lot for this! I found another way with trapcode starglow too but not quite the same
Daniel Waldron
on Jun 23, 2016 at 4:14:59 pm
You could also try messing around with a long shadow technique and some masking. Probably won't achieve the exact look in the video this way though.
Wilson Costa Campos
on Jun 23, 2016 at 5:26:04 pm
thanks daniel it is very similar to this!
