RAM preview audio pitch problem (2015.3)
Rogier Degeus
on Jun 22, 2016 at 8:38:38 am
Hello all,
I recently updated my After Effects to 2015.3 and I noticed the audio pitch is fluctuating when my preview speed is less than 25 FPS. (25 FPS being my project settings). It's very annoying and distracting to have the audio pitch change continuously throughout a ram preview. The voice-over I'm using to time my animation is going nuts.
Is there anyway to set the audio to stutter like the previous AE versions whenever playback is a little laggy? I noticed an option to mute audio when the preview is not real-time, but that's not really a solution either.
Help would be appreciated!
Rogier
Walter Soyka
Re: RAM preview audio pitch problem (2015.3)
on Jun 22, 2016 at 10:55:20 am
Would checking "Cache before playback" help you? You can also set "On (Spacebar) Stop" to "If caching, play cached frames" to work in conjunction with that and provide more control over what you're previewing.
Walter Soyka
Rogier Degeus
on Jun 22, 2016 at 2:01:16 pm
Thank you for your reply.
Where can I find these options? I haven't been able to find them in the preferences
Walter Soyka
on Jun 22, 2016 at 2:26:26 pm
They are in the Preview panel:
[image]
Walter Soyka
Rogier Degeus
on Jun 24, 2016 at 7:35:44 am
It doesn't make a difference unfortunately. Am I the only one to experience this issue? I can't see why Adobe would implement such a feature.
Marina Coser
on Jun 26, 2016 at 11:19:16 pm
I'm having the same issue as audio doesn't play normally for more than 3 seconds (it then slows down and gets really low). I'm on a 29.97 timeline
