How to animate a wire swinging through the air
Aleksandar LJubomirovic
on Jun 21, 2016 at 7:38:55 am
Hello
I have to animate two lamp posts pops onto the scene by rotation from the bottom anchor point.There is a wire that connects two lamp posts. How can i connect wire and lamp posts to act together when pops onto the scene?
Wires should act similar to this video made by Josef Atlestam:
https://vimeo.com/124181378
Thanks in advance for yours suggestions.
Walter Soyka
Re: How to animate a wire swinging through the air
on Jun 21, 2016 at 1:46:36 pm
This is easiest with a dynamics simulation. You might approach it in C4D instead of Ae, or consider a tool like Newton:
http://www.motionboutique.com/newton/
Walter Soyka
on Jun 21, 2016 at 10:19:34 pm
I also have to try Newton.
Kalle Kannisto
on Jun 21, 2016 at 6:44:16 pm
Three puppet pins on the wire, with two attached to the poles and one doing the "swinging," might work fine.
on Jun 21, 2016 at 10:18:24 pm
Thanks. Probably it's beret if I use Duik script and make bones from pins.
