How to move the vertices of a shape layer's path individually?
Filippo Marchetti
on Jun 19, 2016 at 4:23:31 pm
Hello.
I have a rather simple question.
How can i move each vertex of a shape layer's path individually?
I refuse to think that this is impossible; i cannot animate shapes efficiently with only a keyframmed value which dictates the full shape.
I'd like to do something similar to what this plugin does:
http://aescripts.com/bao-mask-avenger/
I'm saving money for that plugin, but i need to solve this issue for an upcoming project.
I don't care if i have to use weird expressions or techniques, as long as you explain me how to do everything.
Thank you very much.
https://vimeo.com/revandesign
Kalle Kannisto
Re: How to move the vertices of a shape layer's path individually?
on Jun 19, 2016 at 6:33:23 pm
See Path Editing Mode here:
https://helpx.adobe.com/after-effects/using/animating-shape-paths-masks.htm...
Filippo Marchetti
on Jun 19, 2016 at 7:32:45 pm
I need to be able to keyframe the vertices separately.
The guide you showed me doesn't explain that.
