best way to align clips from 1 to 10 playing clip 1 then 2 then 3 so on
hanna dean
on Jun 16, 2016 at 10:44:37 am
in the timeline i will add 4 clips so all layers are on top of each other now how will i align each other so when i press plays clip from 1 to xxx
its easy to do this manually on clips less then 4 but i have over 20 so doing it manually its not good.
its there a quicker way to do this.
Tero Ahlfors
Re: best way to align clips from 1 to 10 playing clip 1 then 2 then 3 so on
on Jun 16, 2016 at 10:55:04 am
Select the layers and use the sequence layers command.
Mike Kruft
on Jun 16, 2016 at 11:07:10 am
To align layers quickly it is possible to use the shortcut keys [ and ] which ripples the layer and alt + [ and alt + ] which trims the layer.
http://www,mediamaker.co.uk
