Selecting key frames
Gonçalo Perdigao
on Jun 14, 2016 at 8:49:50 am
Hello, I have 900 layers with position keyframes, just in and out.
I want to select the first keyframe of each layer, is there a shortcut or a script I might use?
Because is taking me 20m to select the keyframes when after effects don't crash on me.
Cheers
Kalle Kannisto
Re: Selecting key frames
on Jun 14, 2016 at 1:24:01 pm
If you select all the layers and press "p" you will see only the position keyframes for all layers. Then you can drag around a bunch of keyframes to select them, and shift-drag to add to the selection. Just be careful not to start the dragging on a layer, but in the space holding the keyframes.
Gonçalo Perdigao
on Jun 14, 2016 at 1:26:40 pm
Thank you for you reply!
That works when you just have a "few" layers, now when you have 900, is not so easy to select them.
What I did in the end was just selecting a bunch at the time holding the shift key.
But it must be an easy way (expression or shortcut) to select these amount of key frames.
Cheers
