Getting curved path points between keyframes
Matt Shoesmith
on Jun 13, 2016 at 10:51:35 pm
I have a simple horizontal path on a keyframe.
On the next keyframe I have an S shaped path.
How can I get better curves on each line point during the transition between those 2 keyframes? Right now the bezier handles aren't being adjusted enough causing the in-between frames to have corners on each point.
Matt
Tudor "Ted" Jelescu
Re: Getting curved path points between keyframes
on Jun 14, 2016 at 7:53:38 am
post a screen grab.
Tudor "Ted" Jelescu
Senior VFX Artist
Kalle Kannisto
on Jun 14, 2016 at 1:18:51 pm
It is often easier to handle keyframe bezier curves if you separate the dimensions.
