FreeForm Misaligned with other 3d Layers
Clive Barry
on Jun 12, 2016 at 12:23:33 am
Hi there,
I've found to my chagrin that Mettle FreeForm does not match up with any other 3d layers in the same composition if I move the camera. It will respond to the camera, but in a manner wildly misaligned from the rest of AE 3d space... is this normal??
Many thanks for your help
Clive
Tudor "Ted" Jelescu
Re: FreeForm Misaligned with other 3d Layers
on Jun 13, 2016 at 7:35:37 am
No, it is not. The integration should be flawless. The one thing I can think of is if your other 3d layers/objects are positioned before you create the FF layer. You need to position the FF object in 3d space using the plugin controls to match the x,y,z of the plane you are trying to match it up with. It may be that you need to reset position on all layers to "0" and re-position everything again.
Tudor "Ted" Jelescu
Senior VFX Artist
Clive Barry
on Jun 30, 2016 at 12:23:42 am
You are entirely correct — had the freeform layer set as a 3d layer... ordure for brains!
