change mid-animation keyframe for mask and want ae to take over the changes for following keyframes.
Oskar Sulowski
on Jun 11, 2016 at 6:43:58 pm
Hey, thanks for reading!
Doing some rotoscoping.
I have 25 frames of shapepath for a mask.
I realised that on frame 10 I did something wrong on one side of the path and would like to fix frame ten and have ae take this for the following 15 frames.
I do not want to delete the following 15 keyframes, for they have some tough sides.
Any luck?
Oskar
Kalle Kannisto
Re: change mid-animation keyframe for mask and want ae to take over the changes for following keyframes.
on Jun 12, 2016 at 6:17:06 am
If the correction is adding to the shape, you could use another shape and animate it. If it is to delete from the shape, you could precomp and use a mask.
Oskar Sulowski
on Jun 13, 2016 at 1:44:43 pm
Thank you, helped me a lot!
