File won't show up in timeline
Seth Johnson
on Jun 11, 2016 at 3:53:41 am
Dynamic Link Premiere files will transfer to AE, but when I drag them to the AE timeline, nothing shows up. The timecode accurately changed to the file time and I get a green render bar above the timeline, but no visible file.
I've been doing this for years and never had a problem until now. I tried to update both programs and that didn't work.
Greatly appreciate any help!
Seth Johnson
Re: File won't show up in timeline
on Jun 12, 2016 at 10:38:40 pm
I'm also unable to render anything out of the Premiere project using the Encoder. It says "failed" and provides the following info:
- Preset Used: HD 720p 23.976
- Video: 1280x720 (1.0), 23.976 fps, Progressive, 00:53:30:16
- Audio: AAC, 192 kbps, 48 kHz, Stereo
- Bitrate: VBR, 1 pass, Target 6.00 Mbps, Max 10.00 Mbps
- Encoding Time: 00:21:52
04/10/2016 09:47:07 PM : Encoding Failed
- Encoding Time: 00:06:19
04/18/2016 04:32:05 PM : Encoding Failed
Export Error
If audio is in 2-pass VBR encoding mode, try either CBR or 1-pass encoding.
Export Error
- Encoding Time: 00:08:29
06/12/2016 04:40:43 AM : Encoding Failed
A low-level exception occurred in: Lumetri Color (AEVideoFilter)
I'm not sure what to make of this besides a possible error concerning Lumetri filters and audio encoding.
