Opacity color math
Jerry Smith
Opacity color math
on Jun 10, 2016 at 6:07:17 pm
So, I have a colored square with 100% opacity on a white background. I'd like to replace it by a darker colored square with 50% opacity. Is there a simple formula or web site with a color applet that I can use to calculate how to go from the hex for the original color to the hex for the darker color?
Richard Herd
Re: Opacity color math
on Jun 10, 2016 at 7:14:53 pm
Have you tried Adobe Color? https://color.adobe.com/
EDIT: here is some blend mode math http://photoblogstop.com/photoshop/photoshop-blend-modes-explained
Kalle Kannisto
on Jun 11, 2016 at 6:38:39 pm
You can calculate it by the RGB values
r1=255-(255-r0)*2
g1=255-(255-g0)*2
b1=255-(255-b0)*2
You'll see the hex value in the color picker dialog if you plug in the results there.
Note that if any of your original R, G or B values are below 128, the resulting color doesn't fall into the RGB gamut.
