fully automatic selective frame mix with sampleimage
Chris Wright
on May 3, 2016 at 5:01:13 am
Whenever you need to change framerate of video in AE, it frame blends every single frame whether it needs it or not!
so I made a script that only frame blends the images needed to not be simply duplicated. This creates the positive effect of not damaging every single frame.
i replaced the counting math with a sampleimage expression. now it automatically decides to ignore duplicate frames by reading the pixels and dropping to another layer with full quality. and now smart edit detection built in.
ae cs6
-automatic selective frame mix with sampleimage
ae cs6-automatic selective frame mix with sampleimage while framemixing only duplicate images - Creative COW
https://f1.creativecow.net/10043/ae-cs6automatic-selective-frame-mix-with-s...
Chris Wright
Update :fully automatic selective frame mix with sampleimage
on May 6, 2016 at 4:05:03 am
update: now works with any framerate!
ae custom 50-50 opacity frame blend with autofps and scene detect cs6 working
to use:
make both comps same fps. use text edit control to change edit tolerance so it won't blur edit cuts.
will remove duplicates and blend 50-50 instead of adobe 25/75%. higher quality
ae cs6 download link
https://f1.creativecow.net/10063/ae-custom-5050-opacity-frame-blend-with-au...
