Noise effect
Menno Wisselink
Noise effect
on Apr 13, 2016 at 2:26:03 pm
Hi guys!
Im wondering how to do these kind of noise effects you see in the picture below;
+ Was wondering how to add noise on just a certain part of an object, and how to let the noise track the movement!
Many thanks,
Menno
Kalle Kannisto
Re: Noise effect
on Apr 13, 2016 at 5:08:46 pm
The easiest method would be to build the noise right into the animated pieces (layers). Photoshop brush with some airbrush/noise/scatter-type settings would do it.
Animated noise is a bit more involved. You'd either have to do three versions of each piece and circulate them, or precomp an animated fractal noise layer with a soft mask to each one of them.
I'm pretty sure that a static (non-animated) noise will -- aside from being the easiest -- look best.
