accidental masking with Selection Tool
Bob Cole
on Feb 14, 2016 at 12:44:05 am
I have a layer selected. I have the Selection Tool activated. I try to move the layer in the comp window, but instead of an arrow, I have a crosshair, and I start drawing a mask. The mask is applied to the comp itself, not a layer. Once I have "drawn" this mask, I can move the layers at will, but I have to expand the mask to the entire comp in order to access the layers.
I know that I must have made some change to make this happen but I have not been able to find the toggle.
Your advice is most appreciated.
Bob C
Kalle Kannisto
Re: accidental masking with Selection Tool
on Feb 14, 2016 at 10:18:34 am
Sounds suspiciously like a program error. Does the problem persist if you close and open the program?
Bob Cole
on Feb 14, 2016 at 12:25:49 pm
Not only did I close, restart, re-open AE, but I tried two different versions of AE with the same result.
Kalle Kannisto
on Feb 15, 2016 at 8:24:00 am
Ok, it must be the region of interest tool then. The icon between the comp resolution and toggle transparency grid. Turn that off.
