Technique to remove lens vignetting in a clip with mocha?
JonZ MarZ
on Feb 6, 2016 at 2:00:25 am
hello,
I am using mocha to stabilize a shot in a clip, but the lens vignetting as a result is moving around inside the footage. I'm trying to find a way to remove lens vignetting in my footage so I may put an artificial one later that doesn't move.
Is that possible?
Kalle Kannisto
Re: Technique to remove lens vignetting in a clip with mocha?
on Feb 6, 2016 at 2:50:28 pm
Remove the lens vignetting first then stabilize the footage. Then add a new one back in.
JonZ MarZ
on Feb 6, 2016 at 7:27:37 pm
Do I need a specific filter to remove the vignette? I know that in Lightroom I can remove it by selecting my lens model and LR will take care of it, but I think it doesn't work for clips.
Kalle Kannisto
on Feb 7, 2016 at 5:28:21 pm
I use curves effect on an adjustment layer with a soft circular mask.
