Turbulent Displacement - Offset turbulence (ONLY MOVE Y Axis)
David Wood
on Jan 29, 2016 at 9:39:51 am
As title says, I want to animate my turbulence but only on the offset Y
I tried "Converting" a script to only move an objects position on the Y Axis to the displacement but that didnt work
Michael Szalapski
Re: Turbulent Displacement - Offset turbulence (ONLY MOVE Y Axis)
on Jan 29, 2016 at 8:43:52 pm
You could use the Displacement Map effect and only push pixels in Y.
- The Great Szalam
Dave LaRonde
on Jan 30, 2016 at 2:05:17 am
I'm with Michael. If you can't do what you want with his suggestion, it would be VERY tough to do in AE.
Dave LaRonde
Promotion Producer
Aaron McLane
on Feb 28, 2018 at 12:09:38 am
I use this all the time for smoke and fire.
Here is the expression:
[1920, time*-150]
Your offset will move upwards like smoke or fire.
The "1920" is the X position. It can be changed to any position but it remains static so it really doesn't matter.
The "time*-150" is the rate and position your offset moves. Negative values go up (odd I know) and positive values go down. The 150 can be changed to affect the speed.
Hope this helps.
Richard Garabedain
on Feb 28, 2018 at 8:03:00 pm
Use a fractal noise instead maybe?
