Compositing Airplanes Question
Alon david
on Jan 11, 2016 at 10:56:17 pm
Im a little new to after effects. I have a project where I want to composite airplanes in the sky. The planes would be from the pov of someone down below so the plane doesnt have to be detailed. I even have footage of a plane that I took in 4k at the park. How do I go about composting the plane onto a different sky. Should I make a freeze frame and composite the plane out and keyframe on a different sky? What is the most efficient way of doing this?
Thanks in advance
Michael Szalapski
Re: Compositing Airplanes Question
on Jan 13, 2016 at 10:52:23 pm
Taking the plane out of a still and animating it yourself might work if you need to adjust the speed for some reason. However, the biggest concern is going to be getting your plane and your other footage at the same angle and with the same lighting. Nothing says "bad composite" like mismatched lighting.
- The Great Szalam
Stephen Smith
on Jan 18, 2016 at 3:49:05 pm
For fun you should check out Red Giants short film Go Bag:
Here is a making of where they show compositing airplanes into the shots:
Stephen Smith
Utah Video Productions
Check out my Vimeo page
© 2018 All Rights Reserved
