Masking for certain rotobrush area
Jakub Frišo
on Jan 4, 2016 at 11:59:21 am
Hello guys, can you please help me by telling me how can I create (simulate) glow of the candle on the the hand and thumbs which put out the fire of candle? I did rotobrush of hand but I dont know how do I have to combine different layer blends to achieve the look ...
Please how would you approach this problem?
Link to problematic footage:
https://www.dropbox.com/s/vlw5zkgbiusmpoo/Sequence.mov?dl=0
Sending pictures of my composition and different layers i hope that will help you. If you will need any more informatiom just tell me ...
Thank you so much
Raw Comp: https://www.dropbox.com/s/t9plzdtzjb25f4t/Raw%20comp.jpg?dl=0
Comp with added layers: https://www.dropbox.com/s/2jxrn6b4j4mvr7p/Edited%20comp.jpg?dl=0
Different layers: https://www.dropbox.com/s/ub4cwvph8zvb5zi/Layers.jpg?dl=0
Hand that needs to be rotobrushed (i didnt add roto yet because i want to know how will I make hand glow with mask):
https://www.dropbox.com/s/xsfe9rmtiebitle/Rotobrush.jpg?dl=0
Dave LaRonde
Re: Masking for certain rotobrush area
on Jan 4, 2016 at 10:34:09 pm
I have to ask myself -- why was this not shot with the hand extinguishing the flame in the first place? It could have been done easily. It may have taken a few takes, but you would have had the job done. All because someone didn't want to have to say "ouch" from the heat, which could have been easily solved with a moistened finger and thumb.
Now you have to re-create the thumb to put it in front of the candle flame and re-create the snuffed-out candle and wick, with a little stream of smoke rising from the top. Not to mention the almost-irrelevant influence of a candle flame on a scene shot in daylight... which was the original problem you mentioned.
Which sounds easier -- hour after hour after hour of painstaking After Effects work, or a re-shoot to do it the right way?
Dave LaRonde
Promotion Producer
