Creating an EKG waveform
Ron Moore
on Nov 23, 2015 at 8:33:47 pm
I'm building a financial news open and need to assemble a motion graphic pulse across the screen and looking for the most effective means of generating that waveform. I have After Effects 2015 (and Cinema 4d) but think that Particular may be the quickest route to go. Any suggestions?
Kalle Kannisto
Re: Creating an EKG waveform
on Nov 24, 2015 at 7:53:02 pm
I'd do it in Particular. That way you can get some variation into it.
If variation is not needed, you could do it with a shape layer with trim paths by drawing the exact path, then blur it, and then fade it with a gradient track matte if necessary.
Daniel Waldron
on Nov 25, 2015 at 8:25:05 pm
I'd go the shape layer route. Draw a line with the pen tool, add trim paths, and you're done! Ok, maybe not quite; you can spice it up of course, but that's the basic idea.
