How do you think this Title Animation was done?
Oliver Saintilien
on Sep 23, 2015 at 8:49:21 pm
I really like the intro and outro title animations on the Grit Grain Trailers. Do you think this could have been created in AE? Or was this hand drawn?
Thanks for your time.
Oh and also, if AE, How would you go about re-creating that lucid liquid transition effect, along with the liquid character reveals?
Daniel Waldron
Re: How do you think this Title Animation was done?
on Sep 23, 2015 at 11:11:08 pm
This could certainly be done in AE. Use the pen tool to draw a shape layer stroke back and forth over your footage (basically, in whatever order you want your graphic to appear), then add the Trim Paths layer effect to it and keyframe the start or end to draw over your footage. Put this layer over your graphic and set it to Alpha Matte or Alpha Matte Inverted depending on if you want it to animate on or off.
The liquid look is a similar concept. You could duplicate your stroke shape layer, make it an adjustment layer, then add a warp or distortion effect.
Oliver Saintilien
on Sep 27, 2015 at 1:54:01 am
Great, will give it a shot!
