How to create light streaks a long hundreds of paths?
Ferenc van der Velde
on Aug 12, 2015 at 1:25:30 pm
Hi all,
I would like to simulate a timelapse of traffic for one country. I have drawn all the main roads (hundreds of strokes) and now I would like to animate light streaks along these paths. At the moment I am using dashed lines and animating the offset. Then I use the echo effect to give it the looks of an energy beam.
The problem with this method is that everything moves quite linear. To simulate a timelapse I would like to have a particle system in witch each particle picks a random path and has a different speed and life time. I am familiair with Particular, but I haven't find a method to use it with random paths.
Maybe there is another way to accomplish this?
Thanks in advance!
Kalle Kannisto
Re: How to create light streaks a long hundreds of paths?
on Aug 13, 2015 at 9:12:03 am
You could probably use this technique:
In brief, create lights that travel along the paths and make Particular use those lights as emitters.
on Aug 13, 2015 at 10:38:58 am
Yeah I thought of that, but when you have hundreds of paths, the project becomes to slow to work with. I am now trying a simpler approach by using radial pulses (scaling circles with some turbulence displace ) and using all the roads as a track matte. It's a lot better already, and not that slow anymore.
