keep plexus objects from flying into/too close to the camera?
Tom Marquis
on Aug 4, 2015 at 9:27:53 pm
Hey guys,
I was curious what the most efficient way to keep plexus objects from flying into/too close to the camera? Is depth of field the only way?
Tom
I have a similar problem with objects passing through the camera in C4d. I tried adjusting the clipping plane but it just produces a hard cut off as objects come close to the camera.
I would rather not spend the time to render DOF, but if you a have a suggestions/tips on efficient DOF settings for AE and C4D I would love to hear them.
Best,
Tom
http://www.risemotion.com
@rise_motion
Boulder, CO
Kevin Dazet
Re: keep plexus objects from flying into/too close to the camera?
on Jan 26, 2016 at 8:43:53 pm
Hey Tom,
I'm curious if you ever figured out a solution to this. I'm having the same issue and wish there were some kind of "near vanish" function...
Kalle Kannisto
on Jan 28, 2016 at 4:45:17 pm
Adding a spherical field of about 500 unit radius and linking it to the 3D camera position worked nicely for me.
