Adjust Timing in Pre-Comp to Top Level Audio
Mark Chadwick
on May 20, 2015 at 6:35:36 pm
What is the best way to set the timing of animations in pre-compositions while running the audio at the top level? In other words, I want to have the pre-comp timeline open, while running playing the voice-over at the top-level. Currently, I am switching between the two, and the time scales are different--very tedious.
Dave LaRonde
Re: Adjust Timing in Pre-Comp to Top Level Audio
on May 20, 2015 at 10:19:25 pm
You could put a copy of the audio in the precomp, and just turn off the precomp layer's little speaker icon in the main comp.
Although I have to say, I almost never render out files containing audio. I just use audio in AE to time out animations. The audio is almost always somewhere else... like in a video editing application, all in place and ready to go.
That's true even for lip-sync audio. I have never had a problem. Not once.
Dave LaRonde
Promotion Producer
Mark Chadwick
on May 20, 2015 at 11:07:11 pm
Thanks for the reply, Dave. Actually, that's what I ended up doing, and I was able to create a relatively smooth process. In case others are interested, here's the process in more detail:
1) I have about 15 separate scenes that are all pre-comp
2) At the top-level I added makers to the voice-over audio where each of the 15 scenes should start
3) After all the markers are down, I copied, pasted the audio track to all scenes.
4) Of course the audio track is much longer than each scene. I temporarily made the pre-comp the same length as the entire audio. Then I shifted the audio so the respective marker matched the start of the scene. Then I reverted back to the original pre-comp length.
5) I can now play the audio local. Because of the markers, it is exactly matched up with the top-level audio. I turn off the pre-comp audio when I'm done working on the individual piece.
I'm still open to suggestions if anyone has some more insight.
