After Effects - Camera, Frame Rate, Pixel/sec question
Randy Frykas
on May 13, 2015 at 8:56:51 pm
Hi there,
I'm currently working on a music video shot 24.00p with the Panasonic GH4. It's a series of locked off performance shots against a wall that I then stitched together side by side etc. I created a camera to "truck" to the right down this long wall that I created, going past the band members performing in different spots with different instruments etc.
The stitching worked great, I've created the biggest jam space in the world. It's the camera move that is causing me issues.
To get the smoothest results does my camera speed (pixel/sec) have to be a certain number related to my frame rate?
Dave LaRonde
Re: After Effects - Camera, Frame Rate, Pixel/sec question
on May 14, 2015 at 5:41:44 pm
You're experiencing a phenomenon known as judder. Unfortunately for you, it occurs at lower frame rates like 24p; it's far less common at higher frame rates. Here's a good explanation:
http://kb2.adobe.com/community/publishing/908/cpsid_90843.html
Dave LaRonde
Promotion Producer
