How should I create this effect in after-effects
bino nicolas
on May 4, 2015 at 12:57:23 am
Hello,
I would like to re-create this effect. I haven't words in english to explain it... so let see what it looks like :
So i you have some ideas, let me know.
Many thanks.
Derek Boettcher
Re: How should I create this effect in after-effects
on May 4, 2015 at 4:52:01 am
That particular effect is practical. Video feedback is created by recording your subject in front of a display that is displaying the camera feed. Tilt the screen or camera to get those neat into infinite images. There are a few days you might be able to go about recreating something similar. If your subject is on a Hendren, key then out and make multiple copies and then Keane each copied position and rotation to be a degree off. You can also try using the echo effect. But really the best way to do it is in camera in my opinion.
Best,
Derek Boettcher
Creative Management
BTH Media Group
http://bthmedia.com
bino nicolas
on May 4, 2015 at 8:23:09 pm
Thanks a lot... it's not a bad idea.
I would love to test it, but I haven't the place to do it.
So i will try with the echo effect or, I also find some plugins like :
http://3dtutorials.net/tutorials/after-effects-layer-control-the-repeater-p...
http://aescripts.com/layer-repeater/
I have to test.
Thanks !!
Martina Scala
on Jun 17, 2015 at 11:17:26 am
I´ve done something similar just for fun and I used exactly Echo then with soundkeys I animated the rotation of the clones
In your case I think you should play with rotation and pos manually.
