Adding wiggle to multiple layers
Thomas Philipp
on Apr 29, 2015 at 3:43:59 pm
I want to animate a very simple crowd for a background. I want the heads to wobble like in this animation:https://dribbble.com/shots/1903171-High-Dive-Closeup?list=searches&tag=pool&offset=3
i already managed to get it working by simply creating many circles(shape layers) and adding the wiggle effect(animatin preset) to all of them. the problem is: if i want to tweak the general speed or distance of the wiggles, i have to enter every single layer and change it individually.
is there any way to simply change the parameters on all layers at once, without entering every single one?
i tried an adjustment layer. but when used, it makes all the circles do the same movement synchronised.
any help would be greatly appreciated :)
Dave LaRonde
Re: Adding wiggle to multiple layers
on Apr 30, 2015 at 4:39:02 pm
Not really. That's the thing about making a lot of layers do the same basic thing, but not quite the same thing. They need to be adjusted individually.
Dave LaRonde
Promotion Producer
Michael Szalapski
on May 6, 2015 at 3:58:04 pm
You could add two Expression Effects to a master control layer and tie the numbers in your wiggle expression to the values of those effects. Then just paste that expression to all of your layers.
Done.
- The Great Szalam
