add Lens Blur effect using composition
max rusakovich
on Apr 16, 2015 at 10:09:01 am
Hello!
I want to achieve this result
I try to create new comp COMP1 add shapes, add adjustment layer, but adjustment layer influence on shapes.
Then I create adjustment layer in my main composotion, add lens blur, use Blur Map.
But I can't animate this map!
Maybe you know more simple solution.
I want to create amimated layer with text that can blur background at the main composition.
Thank you
Dave LaRonde
Re: add Lens Blur effect using composition
on Apr 17, 2015 at 4:36:31 pm
You can use the nested comp as an adjustment layer, you know.
I don't see the layer using the effect; the Switches panel isn't visible. I guess it's the nested comp.
Dave LaRonde
Promotion Producer
