How to make video of hearts go up slanted to center
Ronald Czarnecki
on Apr 14, 2015 at 4:03:59 pm
I am making a title called "hearts for Heaven" and for the back ground I am using hearts video that goes up but not inward towards the sun.
Is it possible to apply some kind of warp and have the hearts diagonally move towards the center?
Dave LaRonde
Re: How to make video of hearts go up slanted to center
on Apr 14, 2015 at 4:48:46 pm
use a particle effect. Run it backwards.
Dave LaRonde
Promotion Producer
Ronald Czarnecki
on Apr 14, 2015 at 5:02:32 pm
I knew that was going to be suggested, I guess it's time to learn Particle. which particle should I use and could you point me to a good tutorial?
(not sure if the hearts will look the same)
Simulation:
CC particle Systems II
CC particle world
Particle Playground
Dave LaRonde
on Apr 15, 2015 at 4:40:50 pm
Start with the free stuff: CC Particle world. See if it does the trick you you. You'll find a user manual on the Cycore web site, and BOATLOADS of training stuff here:
http://blogs.adobe.com/aftereffects/2010/01/getting-started-with-after-eff.html
It even contains links to a great series of tutorials here on the cow by Andrew Devis, which may be of great use to you.
Dave LaRonde
Promotion Producer
