Trapcode Particular Split clip Asynchronous
Viktor Andersen
on Feb 15, 2015 at 1:09:48 pm
I'm trying to make a video of some fruit falling down and i've had some difficulties making it look good. My latest attempt has been to film the fruit falling in 60p on a bluescreen, then i'd use twixtor to make them even slower, because i want a slow falling effect. And then i'd use Trapcode particular with a sprite particle set to split clip and the settings set to freeze the particles, and then just play the clips. But this creates a problem, because the clips being played are not synchronous, they don't play at the same frames, which creates lag.
You can see the problem here, sorry for the short render:
So i was wondering if anyone knows why that is, and how I could fix it, id really appreciate some help. And also, if anyone has any better ideas how to do it, that would also be nice. I've been thinking of doing it in 3d, but i have no experience there, so if you know any tutorials, that would also be helpful.
