AE Puppet Tool Problem
Milos Milunovic
on Feb 4, 2015 at 6:51:54 pm
Hello and thanks in advance. I hope someone will help.
I imported one file with layers from illustrator in AE. On one layer I'm working with puppet tools and when I tried to copy pins on the other layer that layer deforms. Both layers need to move simultaneously. something like arm and sleeve of a jacket.
I switch on continuous rasterization and nothing. Also I'm using Duik – DuDuF for character rigging.
Any suggestion?
Thanks.
Michael Szalapski
Re: AE Puppet Tool Problem
on Feb 5, 2015 at 6:10:39 pm
Could you precompose them and apply the puppet tool to the precomp?
- The Great Szalam
Milos Milunovic
on Feb 6, 2015 at 8:12:25 am
Thanks for replay.
I forget to mention that I precom the illustrator files an then use the puppet tool on precomp, just like you describe.
My bad sorry.
Jason Jantzen
on Feb 6, 2015 at 12:09:39 am
You do know that the Continuous Rasterization switch breaks the puppet tool effect, right?
Jason Jantzen
vimeo.com/jasonj
Milos Milunovic
on Feb 6, 2015 at 8:20:51 am
Continuous rasterization is switch on the illustrator layer in precomp, and then I used puppet tools on precomp. Something I forget to mention earlier. Sorry.
Does it still break the effect?
