After Effects -Exporting animated signature to Premiere Pro CS5
Ashraf Aziz
on Dec 16, 2014 at 10:36:33 am
Hi everyone, I created a wonderful animated signature in After Effects CS5 and within Premiere Pro CS5 I imported the AE composition and added it to my initial video, but unfortunately while the animation works fine, the signature has a white rectangular back ground which I failed to make it transparent to show the animated signature only over the video. I would appreciate very much helping me to do that task. Thank you in advance. You are great.
Dave LaRonde
Re: After Effects -Exporting animated signature to Premiere Pro CS5
on Dec 16, 2014 at 7:32:41 pm
Go back to the After Effects project and get rid of the white background layer.
Dave LaRonde
Promotion Producer
Ashraf Aziz
on Dec 16, 2014 at 9:30:54 pm
I could figure a solution to the problem by adjusting the opacity of the composition in AE, and making some slight editing in Premiere Pro. I may add that I got a better result in achieving my above mentioned target by selecting the opacity blend mode "Linear Burn" and changing the position of the signature under motion effect.
Dave LaRonde
on Dec 16, 2014 at 9:53:43 pm
I don't know how you made the signature. Write-On is good, Stroke not so good.
But both give you the option of painting on a transparent background rather than the layer. Using that option could help a lot.
Dave LaRonde
Promotion Producer
Ashraf Aziz
on Dec 16, 2014 at 10:37:23 pm
The steps I followed to make the animated signature were as follows:
1) I scanned a handwritten signature and I saved it as a TIF image
2) I imported the above mentioned image in Adobe After Effects
3) I used the pen tool to mask the signature
4) I created a white solid composition
5) I copied the masks to the White solid composition.
6) I copied the white solid masks to a new video composition with same size of my Premiere pro project 1920x1080 and I started to amend the brush size, hardness...etc under stroke
7) I made the end of the stroke feature to be 0% at the start
8) After 3 sec. I made the end comes back to 100%
9) I checked the animation of the signature and it was great, I made the length of the composition becomes 20 sec in length to match the handwriting natural speed
10) I resized the composition to show a size of my signature which does not exceed a 10% of the quarter of the right corner of my video and I selected a transparent background (which did not help in making the rectangle behind the signature transparent), I decreased the opacity to 50% then
11) I opened the Premiere Pro and imported the compostion and I selected the settings I described earlier and at last it worked perfectly.
Dave LaRonde
on Dec 16, 2014 at 10:55:42 pm
You missed a step: in the stroke effect there is a drop-down where you can put the stroke on the original image or on transparent. In your case, it should be transparent.
Dave LaRonde
Promotion Producer
Ashraf Aziz
on Dec 16, 2014 at 11:27:45 pm
Dave, you are absolutely right. I missed this crucial setting. With your help I could put back the opacity to 100% and the result is even better. I appreciate your kind help. Many thanks.
