Animated Heat Lines
Josh Dekay
Animated Heat Lines
on Nov 19, 2014 at 6:15:40 pm
Hi there - newer to AE here.
I'm looking to animate the 3 heat lines for an icon - a minimalistic effect nothing fancy.
My first thought was to create long wavy lines, then mask them and simply slide them upwards (thats the look I want). But that won't get me the nice rounded end caps.
Any ideas?
Attached is a snap from Ai so you can see how it looks.
Stephen Smith
Re: Animated heat lines
on Nov 19, 2014 at 7:07:29 pm
I think it would be cool to add a puppet tool to them so they don't just get revealed but actually move. Not sure if they makes any sense. Also, to reveal them check out this tutorial:
https://www.videocopilot.net/tutorials/graffiti_writing/
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Josh Dekay
on Nov 19, 2014 at 7:41:35 pm
Hey Stephen,
Thanks for the link, I like how he did the masking there.
After some more experimenting I was able to come up with something that gets me pretty close to what I was looking for with relative ease.
For anyone who is interested, here's what I did:
1. Created a line
2. Stroked it, added rounded caps
3. Added a Wave Warp FX.
This is perfect, although the end caps are a little distorted (tapered as if drawn with a chiseled marker tip), but not too bad.
For the reveal:
1. Set the anchor point to the base of the vertical line
2. Animate the y-scale from 0 to 100.
This also allows me to have them animate while they reveal.
Thanks for chiming in!
Stephen Smith
on Nov 19, 2014 at 7:50:45 pm
Sounds great Josh. You'll have to share a Vimeo link when you are done.
Stephen Smith
Josh Dekay
on Nov 19, 2014 at 7:56:45 pm
Good timing! I was just putting a rough gif together for you!
Jason Jantzen
on Nov 20, 2014 at 5:25:38 pm
You could also just draw a straight line on a shape path, use the twist effector, add trim paths, adjust it to 50% and animate the offset.
Jason Jantzen
vimeo.com/jasonj
Josh Dekay
on Nov 20, 2014 at 7:20:25 pm
Hey Jason, thanks for the suggestion.
Here's what I was going for (minus the initial reveal and not fully refined). Is that possible with your approach?
When I tried out your suggestion the heat lines entered and exited along a twisted line, but didn't persist and wave.
What I liked about your approach is the nice non-distorted caps.
I might be missing something.
Cheers -
Jason Jantzen
on Nov 20, 2014 at 8:04:05 pm
Yeah, that's kind of how I envisioned the heat lines, entering and exiting sort of how steam might behave in real life, but what you're going for is a more stylized approach.
I tried doing your approach only using a solid with the write on effect and the end caps tend to distort much less.
Jason Jantzen
vimeo.com/jasonj
Josh Dekay
on Nov 20, 2014 at 8:20:38 pm
Right on. Get it? Bahaha. :|
Being newer to AE, I'm not familiar with that one. But after taking a quick look, would it basically behave like a mask, then?
Jason Jantzen
on Nov 20, 2014 at 9:05:41 pm
Yeah, a mask path.
Jason Jantzen
vimeo.com/jasonj
Josh Dekay
on Nov 20, 2014 at 9:08:16 pm
Got it - I will check it out/explore it later. Thanks!
