Creating an adjustable gear
Zach Long
on Nov 6, 2014 at 12:58:43 am
I need to make a gear with VERY specific curves. I would pay someone if they could help me with this project, it's that important. I need to make a gear with spokes that can be reshaped, and adjustments will be automatically mirrored around the entire gear.
To do this, I want to create a noncircular segment of two spokes in the gear. Then this segment must be curved along a circular angle, then repeated to go all the way around and complete the whole gear.
For Part 1, I was thinking about putting the noncircular segment onto a circle path, forcing the baseline to follow this angle. Kind of like how you can put text on a path, but instead I want to use a shape. I haven't been able to figure out how to do this.
For Part 2, I want to use a mirror effect to copy the two spokes around the rest of the circle OR copy the spokes along the rest of the circle.
For Part 3, I want to be able to adjust the original two spokes and the rest of the mirrored or copied spokes follow suit. I also need a null controller for stroke width.
So far part one, does anyone know how to force a shape's baseline around a circular path? Or a better method? I'm in great need and seeking a genius or three.
Michael Szalapski
Re: Creating an adjustable gear
on Nov 6, 2014 at 5:02:43 pm
Polar Coordinates. Rectangular to Polar.
If your comp is twice as wide as it is tall, you will have a circle.
- The Great Szalam
