Adjust perspective of text - tracking into a video
TImi Boose
on Oct 25, 2014 at 4:59:13 am
I'm adding text to a blank chalkboard in a video. The camera pans so i need to track it in but also need to adjust the perspective. I've looked under Layer>Transform>Perspective and messed with the Effect>Transform>Perspective but I can't figure a way to move the anchor points separately ... Any advice?
TImi Boose
Re: Adjust perspective of text - tracking into a video
on Oct 25, 2014 at 9:27:55 pm
I made it work by just rotating the text a bit and it looks ok - but really would like to know how to adjust perspective - one anchor point at a time. Is anybody out there?
Daniel Waldron
on Nov 3, 2014 at 3:52:20 pm
Did you use the 3D Camera Tracker? If you have a camera and have your text set as a 3D layer, its perspective or angle should change automatically as the camera moves.
I'm not sure what you mean about the anchor points.
Craig Clark
on Nov 4, 2014 at 3:06:31 pm
You might want to review this tutorial.
Michael Szalapski
on Nov 5, 2014 at 5:48:33 pm
Mocha would probably be ideal for this. What version of AE are you using? It comes free with any of the recent versions.
If you have a really old AE, you can use the standard corner pin tracker.
- The Great Szalam
