How to limit wiggle rotation - feather movemet
Daniele Bonazza
on Oct 10, 2014 at 11:17:52 am
Hi everybody,
I'm trying to apply a "feather movement" to an object.
I gave to the object a pendulum movemet with a wiggle expression and make it fall down.
Now my problem is that I would like to limit the wiggle rotation, to avoid values that are close to zero.
For example I want it to rotate from 10° to 20° and from -10° to -20° and NOT from -10° to 10°.
Is there a way?
I use AE cs6.
thanks
Daniele
Daniel Waldron
Re: How to limit wiggle rotation - feather movemet
on Oct 10, 2014 at 12:50:50 pm
Post in the After Effects Expressions forum. I'm sure the fine folks who browse that section will be able to help you out.
