100's of falling pins like Google's pin map
Kellie Patzer
on Aug 28, 2014 at 11:33:53 pm
Hi Folks
I'm getting ready to begin a project where I'll be applying the same 'falling with single bounce' to 100+ objects that are all offset in their start time as well as XY location.
My initial strategy is to create an animated NULL using expressions then applying it to all 100+ objects then adjusting each NULL's XY location as well as start time.
Is this how you might handle such a project or is there a more efficient way of looking at all this?
Thanks for your time and feedback!
Kellie
Derek Boettcher
Re: 100's of falling pins like Google's pin map
on Sep 12, 2014 at 10:48:09 pm
Hi Kellie,
Try use the repeater tool, you can build objects and repeat them, then tell it to animate how you want. You can also use a repeater on a repeater too, so you can go really crazy on it. This uses shape layers, but as I mentioned earlier you can build them how you want. Evan Abrams did a great tutorial on this:
Hope that helps!
Best,
Derek Boettcher
Creative Management
BTH Media Group
http://bthmedia.com
Kellie Patzer
on Sep 16, 2014 at 4:50:47 pm
Hey Derek
Thanks a bunch for this tip!
Will go watch the video and create a bazillion dropping pins.
--Kellie
Derek Boettcher
on Sep 16, 2014 at 4:55:02 pm
No problem, you should send me the final clip, I'd love to see how it turned out.
Best,
Derek Boettcher
Creative Management
BTH Media Group
http://bthmedia.com
