Modify the thikness along the path
Andrea Di Berardino
on Jul 26, 2014 at 9:48:13 am
Hi guys, i have a scene where i am working with 3d tracker point. I have to do a blood vfx that slips on a face. To do that i used a path. I wanted to know if there is a way to modify the thikness along the path in different points.
Thanks for your help.
Andrea Di Berardino
Richard Garabedain
Re: Modify the thikness along the path
on Jul 27, 2014 at 1:32:32 am
You can create a new solid, add the write on effect, copy the mask and paste it onto the brush path, then animate the size of the brush. That might work.
Andrea Di Berardino
on Jul 28, 2014 at 4:11:19 am
Thanks Richard for the advice. I tried as you said. Here is my first result:
7792_test.mp4.zip
Do you think that might work?
Andrea Di Berardino
Dave LaRonde
on Jul 27, 2014 at 3:33:42 am
Last time I looked at Stroke, you couldn't animate the brush size. I KNOW you can do it using Write-On.
There's a problem with either one -- you're not going to get realistic-looking blood flow. I'd be tempted to do it as a practical effect, with white paint dripping down a black-painted mannequin. Match the angles & size of the mannequin to the live subject, and you ought to be pretty good.
Dave LaRonde
Promotion Producer
Andrea Di Berardino
on Jul 28, 2014 at 4:13:41 am
Thanks Dave for your reply. I tried how Richard said. Stroke + write on.
7792_test.mp4.zip
Andrea Di Berardino
Richard Garabedain
on Jul 28, 2014 at 1:07:52 pm
I like it. It turned out well i think.
