How to make fast move effects?
Adam Smith
on Jul 17, 2014 at 9:00:26 pm
Искам да науча кой ефект или ефекти се ползват в това видео - http://vbox7.com/play:33524c1bc6 (0:23 sec.)?
Somethink like displacement with motion blur. I just can't understand it.
If you know and the text effect I'll be very grateful :)
Stephen Smith
Re: How to make fast move effects?
on Jul 18, 2014 at 4:36:21 pm
At 23 seconds where they transition from one image to the other I would place my two images next to each other in AE so you don't see one. Either add a camera and move it or parent the two images to a null object and then use that to move the two images to the right to reveal the hidden image. Select motion blur and AE will do the rest. However, it looks like the image on the right darkens up as it moves off screen. If you want to do that as well I would just drop it's opacity slightly and make sure nothing is below it or if something is add a black solid. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Adam Smith
on Jul 18, 2014 at 7:12:59 pm
Thank you very much for the answer :)
I understand what confuses me. Motion blur just don't work when I turn on it.
In Effects & Presets I use and CC Force Motion Blur but without any changes!
I have no problems with other effects. I don't understand what I make wrong and why are not visible this effects?
Stephen Smith
on Jul 18, 2014 at 8:19:38 pm
AE's built-in Motion Blur only works with layers that are actually moving. If the layer doesn't move, there's no motion blur. Never mind that something on the layer moves: the layer itself has to move. And the faster it moves the more motion blur you will see. That transition should only take about 20 - 30 frames.
Stephen Smith
Adam Smith
on Jul 18, 2014 at 10:52:40 pm
Now I understand. I had motion but blur started to work well when I made the movement for about only 10 frames. With parents I hope it will work well.
Thanks again for your help!
Adam Smith
on Jul 20, 2014 at 1:19:55 pm
I can't perform the effect. I offset image outside the visible area for 10 frames. The motion blur effect is only 1 cm. How to make more as the effect of the video?
Stephen Smith
on Jul 21, 2014 at 2:49:49 pm
I'm not sure I understand. Take a look at this video I did and focus on the Motion Blur of the images and text: That is the default motion blur settings.
Stephen Smith
Adam Smith
on Jul 21, 2014 at 5:42:40 pm
Yes, that's the motion blur effect that I achieve too. But it's not what is shown on my video. In my video effect is with width of the entire screenq not only 1 cm.
I guess it is done in another way, not with motion blur effect.
Do you have any idea how?
Stephen Smith
on Jul 21, 2014 at 6:17:19 pm
Take a look at the following sample I built.
Blur Test
I built what I described but added an adjustment layer and the Directional Blur Effect. I used keyframes to increase its value from 0 to 250 and then back to 0. See screen grab for reference. Hope this helps.
I played around a little more and I like the direction of the blur at 95%.
Stephen Smith
Adam Smith
on Jul 21, 2014 at 6:49:58 pm
This result is quite... modest (1 centimeter motion blur is not like in the video I showed). I know how in Adobe Photoshop to increase this motion blur. I just feel stupid I have no control over this effect in AAE and how just to boost it!
Stephen Smith
on Jul 21, 2014 at 7:05:50 pm
You can dial up the Directional Blur amount to anything you want in the latest example I gave you.
Stephen Smith
Adam Smith
on Jul 21, 2014 at 8:47:37 pm
I just tried it with Directional Blur and Motion Blur - the result is not the one in the video of my first post ):
I'm sure there is a simple way to achieve this effect, rather than manually setting keys and synchronization of layers ...
Adam Smith
on Jul 23, 2014 at 12:14:32 pm
This is one frame from video:
Adam Smith
on Jul 23, 2014 at 12:17:10 pm
Motion blur is longer than 1 cm:
Stephen Smith
on Jul 23, 2014 at 2:12:05 pm
THis is with the directional blur set to 633 on a black and white image.
Stephen Smith
