Assistance with effects
Roberto Rivera
on Jun 19, 2014 at 12:31:40 am
Hi everyone, new to the forums. Im looking for some direction as to how to go about doing these effects. I have no ideas where to even start. Thanks in advance!
Stephen Smith
Re: Assistance with effects
on Jun 19, 2014 at 2:31:14 pm
Check out this tutorial: http://vfxbro.com/lightstreak/
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Roberto Rivera
on Jun 21, 2014 at 4:01:27 am
wow, that is an excellent find my friend. Very good indeed, Thanks!
Stephen Smith
on Jun 25, 2014 at 4:25:51 pm
Happy to help. Best of luck.
Stephen Smith
JP Pelc
on Jul 3, 2014 at 5:00:09 pm
If you want a less tedious way than drawing on every frame, you can follow these steps:
- Create basic shape that you want to animate
- Create solid and add fractal noise effect
- Change the fractal noise parameters to be long and stringy (you might need to play with these later to get the desired effect)
- On the seed random parameter, alt+click the stopwatch and add the following expression: time*50
- Precompose the solid and select move effects into new comp. Call the precomp "map"
- Hide the precomp
- Add a displacement map effect to the shape layer
- Choose your "map" precomp as the displacement map layer
- Choose "luminance" for both horizontal and vertical displacement.
Voila. You might need to do a lot of playing around with fractal noise to get the look that you want, but once you do, you can use it for a map on every shape you'll be animating, and it will save you a lot of time.
Roberto Rivera
on Jul 4, 2014 at 1:26:37 am
Im gonna try that, thanks! and yea I personally love Joey Badass but I kinda like Mac, especially that last cd he released "Faces". But yea man, I feel like the write on effect for the stroke is great but very cumbersome to work with, lots of layer with built in keyframes that I gotta move around. Im also finding that I have to draw on the actual video itself the copy into a separate layer which is a little annoying
JP Pelc
on Jul 3, 2014 at 5:02:12 pm
On a separate note, it's sad that Joey Badass is making himself look bad by agreeing to be on tracks with Mac Miller
