Mocha AE Problems
Scott Adams
Mocha AE Problems
on Apr 10, 2014 at 10:27:38 pm
I need some assistance if anyone can help. I am using CS 6 and tracked a plane in Mocha AE to place an image over a mirror. The track is solid. But my issue now is trying to get the image to fit the plane selected. I even imported the image into mocha to help out and see if the track was solid. I applied the tracking data to a null to try and see if that would help but so far nothing has worked. Anyone have any way of getting my image to stick on to the plane as it was tracked?
Jon Chainy
Re: Mocha AE Problems
on May 14, 2014 at 12:12:45 pm
in the tracking panel click edit target and select the clip you want to apply the tracking data, if that helps :) enjoy
mathew fuller
on Apr 11, 2014 at 1:31:12 am
The image you want to paste the corner pin data to needs to be the same size as your comp. so...
Place the image u want on the mirror in your comp, make it the same size as your comp (doesnt matter if it is stretched at this point). . I suggest that u then precomp that, and then paste the cornerpin data on the precomp.
Blammo.
My Work:
http://www.morecompletefx.com
Scott Adams
on Apr 11, 2014 at 1:16:08 pm
Awseome thank, Matthew! On to color correction
