Mocha tracking issues
jack zehnder
on Dec 25, 2014 at 4:07:44 am
New mocha user here, and I'm tracking images to peoples faces. In mocha my tracking looks like this http://prntscr.com/5kotm3, where the shape is following the head. Yet when I import it's attributes it looks like this http://prntscr.com/5kottn. I don't get it, since in mocha it tracked perfectly fine. Any help is recommended.
Jon Merrifield
Re: Mocha tracking issues
on Dec 27, 2014 at 3:29:28 am
I love mocha and use it all the time. Great tool.
Here's the thing, it takes a little getting used to. You need to know how it thinks and what it does with the data. Find any tutorials you can, especially those from Imagineer and AdobeTV. and/or continue searching on the Cow and you will discover your solution.
Virtually always an "off track" is one of these things:
You or I have not set and/or pasted to the proper start frame.
Yours or my tracking clip and our comp are not the same size. (Pre-render your track clip to be the same size and match placement in your comp)
Something else is off sync like frame rates etc...
cheers,
Jon Merrifield
PELi VFX
jack zehnder
on Dec 27, 2014 at 3:36:44 am
Thanks, will do.
