What Audio/Visual Sync Effect Is This?
Kevin Huang
on Feb 19, 2014 at 2:51:20 am
I need some help with identifying what the following AE technique is and how I could replicated it:
The effect that I am referring to is the audio and visual sync in which the image will have a "ghost plusing" effect when ever a certain frequency for the audio track is detected (normally a lower frequency/bass). If anyone could help me with this that would be great!
Thanks in advance.
Todd Kopriva
Re: What Audio/Visual Sync Effect Is This?
on Feb 19, 2014 at 6:36:06 am
There are resources here to get you started:
http://helpx.adobe.com/after-effects/using/assorted-animation-tools.html#co...
After Effects team blog
Kevin Huang
on Feb 25, 2014 at 8:30:07 am
Thanks for the resource however I have a couple more questions.
I've used Trapcode Sound Keys instead to produce the audio key frames and wish to add an adjustment layer like the one in the video. I think the video uses curves and scaling to produce the ghost pulsing effect but I'm not too sure on that.
I've used Light Burst 2.5, is that the effect name?
