transition Techniques
Michael Berg
on Feb 7, 2014 at 11:14:50 pm
Hello!
I want to use this kind of transition techniques in this fx brands
http://medialuna.tv/index.htm#/portfolio/34/fxbrands_10_edit
Any ideas how to replicate this in AE?
A kind of card wipe?
Thanks for your reply
Michael
Hi all! I have reinstalled premiere cs3 and an upgrade of cs3, but now when I'm in the timeline I don't see video out in the external monitor, attached to the breakout box of Matrox RTX2...I have checked the preferences and project settings in premiere, but they seem ok.
Any ideas?
Thanks for your reply.
Michael
Dave LaRonde
Re: transition Techniques
on Feb 8, 2014 at 2:07:58 am
Yipes! There is a LOT more going on in that clip than just After Effects. In fact, most of it's done in a 3D application. For something like that, AE is NOT the software of choice, by any means!
Dave LaRonde
Promotion Producer
Michael Berg
on Feb 8, 2014 at 2:40:43 am
ok, a 3D program can do that....but it seems to me that they are 2D plane, just like photo...
Joseph W. Bourke
on Feb 8, 2014 at 2:58:41 pm
Take a look at AE Sweets - that will get you a good part of the way:
http://www.aesweets.com/
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Michael Berg
on Feb 8, 2014 at 4:22:34 pm
Thanks Joseph, very useful script.
Michael
Any ideas?
Michael
Joseph W. Bourke
on Feb 8, 2014 at 4:36:40 pm
Hi Michael -
Since you have an older version of PPro, double check that Sweets will run on CS3 before you buy it, just to be on the safe side.
Joe Bourke
Bourke Media
Joseph W. Bourke
on Feb 8, 2014 at 4:37:52 pm
Maybe a driver update for the Matrox BoB?
Joe Bourke
Bourke Media
Michael Berg
on Feb 8, 2014 at 5:24:41 pm
I don't know why but the Premiere CS3 post is an older one post, it's mine, but it continue to repeat....
George Goodman
on Feb 8, 2014 at 11:54:08 pm
It looks like that post is in your signature, so everytime you post and add your signature (which it does by default) you're essentially posting that question.
"|_ (°_0) _|"
Sincerely,
George
Michael Berg
on Feb 9, 2014 at 12:09:39 am
yes George, you are right
Jason Jantzen
on Feb 10, 2014 at 4:02:54 pm
Looks like lots of precomps with lights and shadows. I've done similar things in AE and it's very much possible to do there. I don't know why a 3D package was suggested for simple animation consisting of flat planes, but you can do this in AE for sure. Getting the look from slide A to slide B will help you figure out what sections to "cut out" and transition. Once you've got your slides set up where you want them, I'd precomp them before "cutting" anything (good procedural habit). Use the mask tool to slice up the precomps. Obviously, you'll need to duplicate the precomp as many times as you need slices. With AE CC the snapping tool comes in very handy to move the anchor point (Pan Behind tool) where you want each slice to pivot. Then go about rotating the slices to reveal the slide below it. I wouldn't focus on the motion being very technical as I would the style of how you think it should move. The example you gave shows very quick movements, like 5-7 frames (at 30fps) max for each slice. Some of it feels like a transformers transition, which is one way to do it, or at least, one style to think about maybe.
Hope that helps.
Jason Jantzen
vimeo.com/jasonj
Michael Berg
on Feb 10, 2014 at 5:51:25 pm
Thanks for your reply Jason, even I think it's not necessary a 3D application for that...like you said it's a lot of precomps and masks work
Michael
