AfterFX Glue gun animating
Tim Wi
on Feb 3, 2014 at 5:49:00 pm
I am using the CCGlueGun effect to get a sort of shrinking globe on some footage. It looks spot on for what I want to achieve and I can change the size of the globe using the [stroke width] or [strength] sliders. However when I try to animate either of the values there is no interpolation between the two in the animation. The values change on the sliders but the globe basically just stays the same size until I un-keyframe it all and change it manually.
I am assuming it is something to do with the nature of the tool but I was was wondering if there is a workaround to this. Annoyingly it is absolutely perfect for the effect I want to achieve, if only I could animate the size of it.
Any ideas
Todd Kopriva
Re: AfterFX Glue gun animating
on Feb 4, 2014 at 12:26:42 am
Wow. That bug has been there for a long time. I guess no one has ever wanted to animate that property before. I can reproduce this bug as far back as After Effects CS4.
I'll let the Cycore folks (the folks who make that effect) know.
After Effects team blog
Tim Wi
on Feb 4, 2014 at 2:55:17 am
I have found a very painful workaround where I can manually adjust the value every frame then render the frame out but this gets extremely tedious very fast. I guess no workaround until they [probably never] fix it. Damn
