Nested Particles in Particular?
Greg Neumayer
on Nov 21, 2013 at 1:10:00 am
I'd like to run an instance of particular with the particles being set to randomly using 1 frame from a 5 frame comp. No problem there.
However, I'd like each of those frames to be a comp that has animation in it's timeline. Can I do this? It seems like particular makes them freeze-frames and doesn't let the sub-comps animate.
My workaround is to have 5 instances of particular on 5 layers, but then I run into conflicts with things in 3D space.
Thanks for any info,
Antifreeze Design
© 2018 All Rights Reserved
